scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
I recently had my 17 sidewinder at the shop for a go over. I told them the belt would sometimes squeal when you stopped. They found the primary spring broke and said everything was good,they installed my new spare belt.. Well I fired it up on the trailer the other day and the squealing is worse then before. Belt still seems tight,,,runs about a good 1/16th" above the secondary. Probably will have to run flush. I was thinking about just installing one of those belt adjusters. Looked at BOP and thunder products. A good idea and what would be your preference? THanks
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Any of the adjusters work well, with that said I use Thunders. With a stock 8JP belt you should be 1-2mm below top of sheave.
Fleecer
- Jun 13, 2014
- 2019 SRX
Remove a shim from the clutch bolt.
scottt
- Jan 30, 2018
- maine
Yes but I thought the belt adjuster would make for a quick change and would be nice to really dial it in. No?Remove a shim from the clutch bolt.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Thunder’s adjuster works great.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I love my Thunder Products belt adjuster!
Fleecer
- Jun 13, 2014
- 2019 SRX
Yes, you are absolutely right. Im not a fan, as I like to keep things simple, but they work.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
..........another vote for Thunder's
scottt
- Jan 30, 2018
- maine
Ordered one last night. Seems simple enough to install after watching YouTube video.
Shims come in all sizes.....Pretty simple
scottt
- Jan 30, 2018
- maine
Well I installed TP belt adjuster...can't get the belt to sit flush..still. a good 1/16" above the secondary, still squeals. Ran it on a stand. With engine off I can move secondary clutch in and out a 1/16" so there's no pressure on the adjustment wheel.
scottt
- Jan 30, 2018
- maine
Forget that,,,had a numb spell
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Did you remove the factory screws on the backside off the clutch? So, to get the belt lower in the sheeves tighten the adjuster to open the sheeves more.Well I installed TP belt adjuster...can't get the belt to sit flush..still. a good 1/16" above the secondary, still squeals. Ran it on a stand. With engine off I can move secondary clutch in and out a 1/16" so there's no pressure on the adjustment wheel.
scottt
- Jan 30, 2018
- maine
Yeah I feel stupid for posting that before thinking. I got in the house and then realized I had yo screw it in the widen the clutch. All it took to not creep and stop squealing was drop the belt down maybe a 1/16". It's still just a hair above..maybe 1/32". We're going riding tomorrow so I'll see how it goes. Still kinda weird with the new primary spring it's engaging at 3500 rpm. I'll have my primary weights with me.
