scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
I can make a quick adjustment tomorrow. That secondary bolt supposed to be like 20 ft. lbs? It took a long 14 mm wrench and another one as leverage to break it free.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
35 ft lbs
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I never go by where the belt is sitting in the secondary, I set the belt tension to where the sled ALMOST creeps forward at idle.You wanna be below the top of the sheeves 1 - 2 mm.
scottt
- Jan 30, 2018
- maine
Creep off the ground, correct? With the track off the ground it creeps tiny bit now and then. Any tighter and the belts squeals pretty bad idling on the ground or off the ground with brake on.
Fords4life
- Dec 7, 2021
- South Dakota
Set proper deflection plenty of info on correct way, that may end up flush, down, or above, me personaly measure my o.d. of belts to get consistency with clutchs a longer belt so it rides outside the secondary for better holeshots...free gearing!
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Yes, sounds like you have it set the way I prefer. Looser means you have lost some power waiting for the clutch to engage when applying throttle.Creep off the ground, correct? With the track off the ground it creeps tiny bit now and then. Any tighter and the belts squeals pretty bad idling on the ground or off the ground with brake on.
Screws on the backside of clutch?Did you remove the factory screws on the backside off the clutch? So, to get the belt lower in the sheeves tighten the adjuster to open the sheeves more.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Here's a video of how to install the Thunder Products belt adjuster....Screws on the backside of clutch?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
See 1:08 for where and how to remove the bolts on the back side of the clutch.
There are no belt adjustment screws on a Sidewinder secondary. The vipers and old school secondaries yes, but not the winders.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
Agree, my bad. When DennyTuna mentioned the screws I assumed this was a SRViper thread. Clearly this was a SW post.There are no belt adjustment screws on a Sidewinder secondary. The vipers and old school secondaries yes, but not the winders.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
Oh crap my bad, those bolts have been ingrained in my brain for 30 years I forgot the winders don't have them...sorry! Thanks Mike for setting me straight.There are no belt adjustment screws on a Sidewinder secondary. The vipers and old school secondaries yes, but not the winders.
KnappAttack
- Feb 19, 2004
- Welch MN
No problem, I just didn't want any confusion for people. I knew what you both meant, but others may not.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
There is also a Thunder Products YouTube video showing the install of a belt adjuster on a Sidewinder if people need it.
Fast
- Sep 25, 2018
I run mine 1-2mm above the secondary and no squealing with the 8jp beltAny of the adjusters work well, with that said I use Thunders. With a stock 8JP belt you should be 1-2mm below top of sheave.
Fast
- Sep 25, 2018
Page 127 of manual says 1.5mm above to .5mm below SecondaryI run mine 1-2mm above the secondary and no squealing with the 8jp belt
