Water temp gauge wiring ?'s
Yah, there is no relay on many of these electric Automobile Temp Gages. You have to hook both the + 12 VDC wires to a keyed circuit. Also, doing so precludes depending on a rely, should you run across a gage that has one.
Hopefully, you did not kill your battery permanently. Before I installed my gage, I did not see a relay. But the wiring diagram looked like it was dependent on one. So, I set up up on the bench and had current flow in the battery wire right off the bat, even though the key switch wire was not yet connected. So I figured there was no relay in the gage either.
Assuming you tapped into the light circuit, it would be wise to add a in-line fast blow fuse that is of just enough value to run the gage. That way, if you short the gage wires, you will still have lights.
