- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Yes, I ran a digital water temp gauge all last season and it worked great. Any questions feel free to ask!
srxspec-- Is this like hooking one up to an RX1 ? I had one in my old sled. What did you hook the wires into and where did you install the probe. If you have a pic of it installed that would be great. Thanx for the reply. What did the temp run at.
BV1
Need more info as well,
-Steve
-Steve
- Apr 17, 2003
- Menno, SD
- Menno, SD
Will take & post some pictures of the setup either tomorrow or Friday guys!
- Apr 17, 2003
- Menno, SD
- Menno, SD
Ask and you shall receive! This is our digital water temp setup that runs for $125. The gauge is simply velcroed onto the handlebar pad. The power wire ties into the blue/white wire so when the engine starts it switches from "clock" mode to water temp reading.
