does anybody have the actual dry weight, or ready to ride weight of the 2006 apex mountain, please no guessing or estimates from the manufacturer. please no second hand info either
pro116
actall dry weight of apex mtn is 615lbs
tomseal6
Ryan,
Please make your avatar and mine the same on this 4 stroke site
Bodacious
How about the actual wet weight...ie: fully fueled and ready to ride?pro116 said:actall dry weight of apex mtn is 615lbs
REXX
- Jan 5, 2007
With engine running and throttle on??...weightless!!
Otherwise; who cares...are you shipping it somewhere??
_____________________________________
'07 Apex mtn SE....outclimb! outdrag! outragious!!!
Bodacious
No..... I'm driving it through the trees and digging it out by myself on occassion. Also really thinking about the Nytro MTX for what I do with a sled, and trying to collect data for comparisom.REXX said:With engine running and throttle on??...weightless!!
SoCoRX1
its around the 700lb mark full of fuel ready to ride.
Nytro MTX will be 100+ pounds lighter. its about 520 dry, smaller gas tank helps a lot with weight. it will definitely be around 560-575 wet
Bodacious
SoCoRX1 said:its around the 700lb mark full of fuel ready to ride.
Thanks a bunch for the info
REXX
- Jan 5, 2007
No..... I'm driving it through the trees and digging it out by myself on occassion. Also really thinking about the Nytro MTX for what I do with a sled, and trying to collect data for comparisom.[/quote]
Yeah...I hear ya. I guess I'm a bit sensitive to the whole weight thing...it must be a self esteem issue .
I agree worming through tight trees at slow speeds is a workout. I practice avoidance and draw my own lines...I don't have to go very fast for it to become effortless.
I learned quick with my RX1 mtn...I'm not liftin' or diggin' nuthin'.
As soon as the sled starts to dig down..I stop and take a look around to see if it's deep snow, a hidden bush, or an uphill slope that's got me. I then wade out in front of the sled and swim out a path in the direction I need to go. I then grab a front ski and swing the front end into the path. Next I use my legs to pack the snow a bit under the front of the track. Then I get on and boot 'er out!
rideblue
Buy a highlifter jack and us it! Weight will no longer be an issue and you can save your energy for riding, not digging and lifting. All sled are heavy when they are stuck!
