What’s everyone using for coolant
mcamzr
Armada MI
Just wondering what everyone’s using for coolant. I just flushed my system and need to fill it up. Long story short the Sled was peeped mixing the green and blue Yamaha coolant and it really mad a mess. So for the last three years I’ve had Polaris 50/50 in it and it was starting to gel up it looks like so I decided to throughly flush it out and start over. Thanks for the help. Mike.
I have been using Polaris 60/40 because that's what the Yamaha dealer carried, but mine is the non gelling kind! Kidding aside, mine has been in both machines for about 10 years since I put the heat exchangers in, and still looks and tests like new. If the Polaris antifreeze is the most accessible to you, I wouldn't be afraid to use it again.
Standard green automotive type, 50/50, with water wetter added to it.
This is my fun and why I ask. I found a post about peak long life 50/50 safe fornall models, but it is orange.
Yamalube's blue coolant or BMW or Mercedes use the same blue coolant with aluminum additives... why save $10 and screw up your cooling system, the blue is specific to what we need, I am sure green or orange will work buy why not use Yamalube where we need so little.
Only 2010 and newer came with blue. Mine is an 09 and came with green. The dealer toped itnoff with the blue and well you can see what happened.
Interesting, my 2009 XTX has blue, assumed it was stock then as well and Yamalube coolant is blue. Maybe the dealer did a change with green, maybe others have green too from dealer.
Honda HP coolant 50/50. Flushed it this fall and temp light has not come on all yr in any snow conditions. Use it in all my machines for yrs
Never mix coolants. If you are going to change to a different one you need to flush the system first.
I thought about Honda 50/50. That is what is in my Rancher and I did think it would be nice to keep it all the same. I have used a Preston’s flush and ran at least 100 gallons of water through the system, and have a new radiator to put in it. Figured it was a good time tomstart from scratch.
Thinking between these two. Don’t know why I make this so hard on myself!!
usually just dump the old stuff and fill with yama cool or if it is an older sled, with prestone premix universal antifreeze that is supposed to mix with anything.
My sled had same problem last year, I used peak long life coolant (green) a few years prior. Ended up changing rad and filling system with Maxima Coolanol. Hopefully no more trouble with it.
Why not use YamaCool? Similar to German blue coolants, designed for our sleds and cheap all things considered.
