We dont know that. He made it sound more like the paint was rubbed off. You think he Acetoned the belt itself? That might make it like glue.He had enough acetone to dissolve the paint on the spring. Anyways I am out on this one, use acetone where rubber and plastic or not your call.
Stingray is being cautious. I guess anything can be messed up. If you use Acetone just be careful to only get it on clutch faces. Some things shouldnt need to be said.What did you mean by this?
BFS
- Jan 26, 2015
- 2016 LTX-LE
Red/White
Allyammis, did you get this fixed, curious of the outcome and what you found!!
Yes hope you figured it out.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I keep coming back to see the out come of this.
allyammies
Not yet worked on it yesterday trying to beat the snow melt.There is a bit of play in the secondary bushing not sure if that is causing the binding, going to the dealer this morning to order one.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
There is suppose to be some float in secondaryNot yet worked on it yesterday trying to beat the snow melt.There is a bit of play in the secondary bushing not sure if that is causing the binding, going to the dealer this morning to order one.
allyammies
This is on the bushing on the back side sheave.Seems worn.There is suppose to be some float in secondary
allyammies
titanrcr
- Jan 3, 2011
- Old Forge, New York
- 2019 Sidewinder LTX LE
2015 Viper LTX SE
2011 Apex
Don't know if anyone can see the wear.Not sure if this is too much?View attachment 112247
That bushing would not cause the problems your'e having, but not a bad thought. I would like to see a pic of the secondary assembled just so we could verify correct assembly... Did you ever lift the rear end of the sled and give the track a turn ? That would rule out all the drive line bearings and chain case. From your description of whats going on with the sled it should be a very obvious problem.
allyammies
Yes tell me about it,track rolls fine.Well good thing I have not gone to buy that bushing yet.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Something happened when you took it apart to clean it, either when you reinstalled the helix the bushing galled in the helix or wasn't straight in tightening it down or something. It sounds that it worked fine before you took it apart and now it won't shift (stuck)?
Still have your stock helix? Put your stock helix back on just to try it, that will tell you if it's in the helix or in the clutch.
allyammies
Ok ill try that when it snows or gets cold again.
How did you get the belt off?
Any luck?
