BA APEX
i had 1900 miles on it.STORM-CHASER said:wow thats what I am affraid of. I am thinking the ice claw track.how many miles you have on that track. Mine has 4000 miles
Not everyone does it for that reason. The reason why I stud my tracks is b/c of ice. Where we ride the corners tend to get very icy after heavy traffic. One 360 into a snow bank and you would stud yours too. Also stopping is important wouldnt you think? on ice rubber does nothing to help you stop. If you are easy on the throttle in bad conditions hopefully you will not have problems. But they definetly weaken the track somewhat.LazyBastard said:The reality of the situation is that most of them do it because *everyone* does it. The group mentality - if everyone's doing it, it must be good.
Like you, I've tried a couple of times on two different sleds and hated the results both times. Steering is compromised and they make you slow. And road crossing is evil.
Another nice thing about NOT running them is that you can chop out all the tunnel protectors. End result is a weight savings of (weight of spikes) + (weight of tunnel protectors) + (weight of ice that the tunnel protectors hold up in the tunnel).
xcsp said:Seems to be alot of tear outs with these Ripsaw tracks.
Don't hear much about others, not that I have seen any polls on track brands and the history of the track and use.
I originally was going to go w/o studs in my Apex, but have since realized that they would be beneficial in safety for icy trail and lake/river riding.
Now I'm hesitant to install the studs as several people have shown the ill effects of studding these sleds.
I have had other sleds with studs and no issues with them, but am concerned with the use of studs in these speceific tracks-sure wouldn't like to think of changing out a front heat exchanger on an Apex!!
Contacted Camoplast, and was told adding the 144 down the center isn't a problem if done correctly.
They did recommend their pre-drilled tracks which are specifically designed to be studded or the Ice Ripper track, which is fine if you are in need of replacing the an existing track.
I understand track damage can happen due to alot of things, but it just
seems more and more people are seeing problems with the Ripsaw.
