yamaha1
- Dec 16, 2005
- Shakopee, MN originaly from Fargo ND
I want to install a temp gauge, but I don't want to cut the line and install a bulky adapter. Wanted something a little cleaner and more factory looking. Was looking over the engine compartment and came up with an idea. Not sure if it will work for sure or not.
Was thinking about pulling out the factory sending unit that screws in just below the thermostat. Screw in a small t-fitting there that has 1/2 npt for the factory sending unit and 1/2 npt on the "t". Then neck the temp gauge sending unit from 1/2 npt to 1/8 npt. I am just wondering if I will get enough fluid flow through there to get accurate readings.
What does everyone think.
Also analog or digital?
Digital and yes I would think you should get close enough readings there. To test get someone with a laser thermometer to check it there against your readings.
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
I would also go digital looks good, if you get it to work please let us know I'd like to do the same with mine.
yamaha1
- Dec 16, 2005
laser thermometer........good idea! You bet, as soon as I get it figured out and installed I will post some pics. Have nothing else to do since it is too freaking warm out and not much snow. Might as well work on it.
STORM-CHASER
I like The digtal. I also have been cheching into option for a temp gauge . I would be very intrested if your plan works. The splice is the best I come up with so far. I found a place that have some nice looking ones, But still would be better your way.
Groomerdriver
Might not want to pull the factory sending unit. I had potential issues with doing that when installing my temp gages. Not sure on the Vector, just thought I'd throw this out.
I am VERY interested in putting in a temp gage. Digital would be cool, but anything that's clean will do. Keep us posted!!!
az99
- Oct 3, 2004
Those gages you have pictured look like Autometer and Dakota Digital or similar. I was warned by reps from both those mfgs. that the gages may not hold up well in a snowmobile application. They are not designed for oudoor use and the temp variations. You may want to check with the gage mfg of choice.
STORM-CHASER
I just bought this one on ebay looks to be a deal. hope it takes the cold weather http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWA%3AIT
yamaha1
- Dec 16, 2005
undecided......what were the potential issues. With voiding the factory warranty? Because I had thought of that as well, and was going to ask my dealer about what all would void the factory warranty if adding a temp gauge.
az99.....what brand gauges are people putting in then that would work? I thought most of what I had seen on this forum were autometers.
yamaha1
- Dec 16, 2005
Stormchaser..........that is the brand of digital gauge that I have pictured above. I just sent an email off to the company to see what they say about the snowmobile application. Will let you know if I find anything out.
Yama-Crazy
- Jan 10, 2005
- S/E Michigan
- 2014 Yamaha Viper rtx
This splice kit is VERY light I'm also installing a digital guage should get it done this weekend. http://www.startinglineproducts.com/catalog.cfm? pageID=detail&catalogID=5&catID=40&productID=512 and this company is great to choose a guage from check it out and if its your first order you get a free hat and catolog. http://store.summitracing.com/ Stormchasers guage is in there for $39.95 w>> Free shipping too
Groomerdriver
yamaha1 said:undecided......what were the potential issues. With voiding the factory warranty? Because I had thought of that as well, and was going to ask my dealer about what all would void the factory warranty if adding a temp gauge.
it was on a Polaris...you didnt want to discon the factory sensor cuz it would mess up the computer...it sensed overheat and retarded the timing. only way I would put a temp gage in my Vector is to put an inline sensor after the thermostat...why take any chances?
yamaha1
- Dec 16, 2005
undecided......were you thinking that I would remove the factory sensor completely? Because I was not going to do that. Was going to take the fitting out put in a T and reinstall the factory one as well as the sensor for the gauge.
STORM-CHASER
Yama-Crazy said:This splice kit is VERY light I'm also installing a digital guage should get it done this weekend. http://www.startinglineproducts.com/catalog.cfm? pageID=detail&catalogID=5&catID=40&productID=512 and this company is great to choose a guage from check it out and if its your first order you get a free hat and catolog. http://store.summitracing.com/ Stormchasers guage is in there for $39.95 w>> Free shipping too![]()
Thats the splice I am going to get there is a guy on the site that has them 25.00 shipped.here is a link to the treadhttp://www.ty4stroke.com/viewtopic ... 007#203007. The guage at summitracing does not include the sender, I paid 45 shipped with sender.they charge anotther 12.00 for sender. The guy on ebay has a website its http://www.speedsolutions.net/?pageid=54000
Groomerdriver
yamaha1 said:undecided......were you thinking that I would remove the factory sensor completely? Because I was not going to do that. Was going to take the fitting out put in a T and reinstall the factory one as well as the sensor for the gauge.
yes that's what I thought you were gonna do...sorry.
- 8K
