rage763
im glad this came up. i am extending my 09 rtx se to 144" oft. i am thinking i would like the backcountry track as well. will i need to upgrade drivers, gearing or clutching?
sleddingfarmer
rage763 said:im glad this came up. i am extending my 09 rtx se to 144" oft. i am thinking i would like the backcountry track as well. will i need to upgrade drivers, gearing or clutching?
I would seriously think about upgrading to Anti ratchet drivers.
Wouldn't be a bad idea to gear down either...not sure about clutching tho.
saskattakman
how many tooth are the factory ones? also im gonna keep my mtx gearing which should be close to going to 8tooth drivers
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
sleddingfarmer said:rage763 said:im glad this came up. i am extending my 09 rtx se to 144" oft. i am thinking i would like the backcountry track as well. will i need to upgrade drivers, gearing or clutching?
I agree. Extro drivers would help and I would drop at least one tooth on top. I dropped 2 when I went to 136x1.75.
Clutching you can wait and see how she runs.
sleddingfarmer
Super Sled said:Why not switch to 8 tooth, 2.52 pitch extro vert drivers? Will be like gearing down a half of a gear for a little more low end power...
I think the only reason you wouldn't want to switch to 8 tooth is because on the RTX you already have a steep approach angle, dropping to 8 tooth would only make it steeper. Not sure how much it would actually matter.
I think if I had to do it all over again, I would have went with 8 tooth instead of 9. I don't do much top speed running anyways.
I thought dropping from 9 to 8 tooth was the equivalent of dropping almost 2 gears in the chaincase. Which is another reason I wanted to do it, a 2 gear drop is about right for a RTX. They only go about 100 mph either way.
UP bushman
Yes changing track drivers from 9 to 8 tooth is equal to lowering gearing by 2 teeth on top gear and steeper approach angle on track. Going from 8 to 9 tooth is equal to raising gearing by 2 teeth on top gear and lowering approach angle on track.
Supa Dexta
I've got an 08 FX that I'm extending to a 144 with a 2" paddle. From reading around I should just go ahead and order 8 tooth extro's..? Oh and 2.52's with what sized shaft?
Anything else to prepare for before I dig in?
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
I just used the extros that come factory on the apex and new sled. My dealer had them on the shelf.
gunner03
I put 8 tooth extro's on my xtx with a backcountry and i dont regret it, gets you some more bottom end and didnt lose a whole lot on the top. gained a little room by the heat exchanger too!
sleddingfarmer
Supa Dexta said:I've got an 08 FX that I'm extending to a 144 with a 2" paddle. From reading around I should just go ahead and order 8 tooth extro's..? Oh and 2.52's with what sized shaft?
If you order Avid extrovert drivers just call them up, they'll know all the info/specs once you tell them which sled you have.
I think going to 8 tooth is the way to go.
rage763
so youre suggesting go with 8 tooth extros and leave gearing alone?? keeping in mind i have an rtx which i am going to extend to 144
sleddingfarmer
rage763 said:so youre suggesting go with 8 tooth extros and leave gearing alone?? keeping in mind i have an rtx which i am going to extend to 144
Thats what I would do if I had to do it all over again. I would have went with 8 tooth extros. And in the process, you'll have dropped about 2 teeth in the chaincase. Which should be about perfect for your 144" big lug track.
saskattakman
so any pros cons to running 8t vs 9 t remember im running my mountain gearing so i dont need to gear down
revster
- Aug 18, 2004
- La Salle MB
rlcofmn said:I'd go with 9 tooth 2.52 Avid's. You have it all apart, might as well put good drivers on it now. Have been hearing more and more people talking that Wahl's do the job as well.
I still think the first response you got was the best one. rlcofmn knows what he is talking about, I would go with what he suggests.
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
I use 9 tooth Ski-doo extros on my 180 MCX Nytro with a 144" backcountry track. They are 2.52 and fits right on the shaft. 3000 kms on them so far, and still looks as new.. Don't know the price compared to avids.. But i went with the doo extros since my dealer had them in stock.
I ran my sled with the 144" backcountry 3000 kms without extros, and had no issues with ratcheting at all.. when i got the turbo.. well thats another story..
