Wilstoon
What is the biggest paddle track that will fit on my attak. I got a good deal on a 2" paddle. just wondering if it will fit. I will have to remove my tunnel protectors but will it hit my heat exchanger? Tired of carving the Grand Canyon behind me in deep snow and not going anywhere.
Phazernut
- Nov 2, 2007
- Torbay Newfoundland
- 04 Viper ER.
96 V-Max 4
Not 100% but with a 2 inch you may have to go to 8 tooth drivers. I just put a 1.75 on my Apex and it is pretty tight with the tunnel protectors removed and stock 9 tooth drivers.
Newfie Apex
- Mar 3, 2010
- Mt. Pearl Newfoundland
- 2008 Nytro
I don't know about 2" We did the track on Phazernut's sled and that was a 1.75..And it was close...Without a driver change forget it...But a 1.75 lug in a 136 would look tough..Craigs 144 is awesome..Wish I had done it
Guess my drivers fit then?
pus1100
- Oct 14, 2007
2'' lug will fit with stock 9 tooth drivers.i've modded my 07 attak with rail extensions to 16 wide 2'' lugs 151'' summit track.stud/front cooler protectors must be removed.made a new tunnel extension and rewelded tubes on rear cooler.
Wilstoon
Thanks for the input. I talked with 2 deals around here. One said only a 1.5" will fit will I will have to remove the tunnel protectors and move the heat exchanger. The second dealer said no problem they do it all the time by just removing the front heat exchanger protectors. I guess the only way to find out for sure is to just get dirty and do it and see for myself.
Newfie Apex
- Mar 3, 2010
- 2008 Nytro
I just put a 1.5" lug track on my '06 Apex...It is close and I didn't remove any tunnel protectors
z1029384756a
Have 2" with 8 tooth extrovert drivers lots of room (tunnel protectors removed), 9 tooth drivers would fit as well as long as the track dosen't rachet. Note even with 2" track you will still trench (not as bad) and backshifting becomes worse be prepared to clutch different and gear lower.
Wilstoon
Well, the track is actually a 2 1/4" measured from the inside of the track (2" paddles). I removed the tunnel protectors, changed the drivers to a extroverts (9 tooth) and dropped top gear to a 21T (need to replace chain with a shorted one). After taking it for a short run the RPM was @ 10,500. So yes 2 1/4" track fits. As soon a we get some more snow I'll see what its like in the deep powder.
bashley
1.5" with no mods. 1.75" and bigger and you'll have to remove tunnel protectors, notch the track, or go with smaller drivers.
