I'm looking to get Air Fuel ratio gauge. The Koso site have both. What is the difference?
Also anyone have experience with Koso A/F gauges and sensors?
Much appreciated!
Koso site is http://www.kosonorthamerica.com/index_us.html
Much appreciated!
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
The narrowbands are useless in a boosted application as they only measures AFR with accuracy in a narrow band around stoich (14.7 AFR). A wide band O2 measures AFR in a wide band from 9 to 21, the sensors are very sophisticated in how it determines the contents of O2 in the exhaust, there by it can detect O2 levels at a high degree of accuracy over this wide band. A boosted application typically makes its best power around 12.0 AFR.
It does make sense. Thank you. That was the first time I was seeing Narrow type band.
So Wide band it is!
So Wide band it is!
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
Narrow bands are to adjust engine a low loads (stoic).
Good for emission and fuel mileage.
