TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
Why can't u rewire the 07 bars as sxray suggested. I did that to my 06 and it worked fine. I never run mine past 2.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
As delivered in '06 the wiring harness caused the grip elements to be wired in series. The '07 update wires them in parallel.
All else being equal, the parallel circuit creates more current flow (more heat).
However the '07 grips have a higher resistance than the '06 grips which mostly negates the benefit of the '07 parallel circuit.
Therefore the '07 parallel circuit combined with the '06 lower resistance grips results in the highest possible current flow.
In fact this combination ('07 wiring & '06 grips) can cause so much current flow that you have to be careful to keep them turned down to avoid melting something.
TBay Sledhead
- Jan 16, 2005
- 06 Attak
01 SXR Long Track
So what is the resistance of the 07 grips. If I only run my grips on 2, the 07 grip resistance cannot be that high that if connected in parallel they will not create more heat if run on a higher setting. Anyone have the resistance of the 07 grips.
06attaker
THE KIT NUMBER, MEANING THE HANDLEBAR UPGRADE KIT FROM 07 WITH THE SUBLEAD IS 8FP-26100-00-KT. IF YOU HAVE AN 06 JUST TAKE THE SUB LEAD ASSEMBLY OFF THE KIT AND USE. SELL THE HANDLEBARS WITH THE WARMERS. COST $29.00. THEY DO NOT SELL JUST THE HARNESS. YOU CAN MAKE YOUR OWN PRETTY EASILY. WIRE THEM PARALLEL INSTEAD OF IN SERIES!!!!!!!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
TBay,
The '07 grips will be hotter if run in the '07 parallel circuit than if they were run in the '06 series circuit. ('07 grips in the '06 circuit would be the worse case scenario)
They just won't be as hot as the '06 grips in the '07 circuit. (this is the best case scenario)
If you are interested in the exact resistance of the '06 & '07 grips, read ROCKERDANS post on this and the very long thread that followed. I recall that someone in that thead posted the two different grip resistances.
