Hi guys, I am stretching my phazer and am adjusting my clutch to that of the mtx. I am having a hard time finding what spring and weights to use and would appreciate some help.
towerrigger
You will have to do a little more than just the clutching to match the MTX. I think the drivers are smaller and the gearing is also different. Unless you already plan to change that.
This should help you out with the clutching. There is a manual in the links. It will have all the part #s and give you an idea what you need.
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
5th post from bottom
OK Thanks, ya I plan the other stuff also.
prozac500
The sprocket you need is a 17th sprocket
Ok, I am having trouble finding what spring and weights for the clutch.
towerrigger
What are you stretching it to? I am assuming that it isn't already an MTX. What is the size of the track you are going to be running? You could try changing it to a 17 tooth sprocket to start out and see what you think of it. You may not need to mess with the clutching.
