What is this and Where does it go??
It came off the extension at the bottom rad mount bolt and fell inside and of course it's not a deepwell. I've got a ton of 10mm sockets (seems everything I everything is 10mm) I just don't want to leave it in there.
Just trying to think what is down there. All I can think of is a starter and the header on the back side, front side would be the throttle bodies. Could it have fell into the header area under the heat shield. I know it is hard to see in there. Not a lot of room around that engine to begin with. Do you have a extendable mirror and shine a flash light on it so you can see into places not otherwise able to.
I dropped one in one time. Take the belly pan off and rock ur sled back and forth real good. It popped right out for me!
That is my next plan. Though I think it fell down next to the header by the tunnel cooler hoses but who knows
Found it!! Only after taking off the skid plate, tank and airbox did I find it wedged on the throttle bodies. Thanks again for the help
woooooo! Game over.
