Mcdoudlehopper
- Oct 23, 2014
- Upper Penninsula (Michigan)
- 2005 YAMAHA RS RAGE
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
They are used to put more pressure on the secondary clutch . The cam should have 4 different numbers 0-3-6-9 and in the inside where the other end of the spring hooks into are 3 different spots numbered 1-2-3. So you added the 2 number up 3-3= 6 then you add an 0 behind so you would get 60% most people if you are on the big side like me I have mine set at 6-1 = 70%. If you want more help in understanding let me know you can call me an I will be glad to help you Jerry 807-274-6907
wavemaster
- Mar 6, 2009
- New Hampshire
- SR Viper XTX, Nytro XTX, Phazer FX
Mcdoudlehopper
- Oct 23, 2014
yes good resource thanks!
