i thought cb was testing one on an srx last season, the belt instead of the chaincase i mean.
towerrigger
I had seen that CB had a picture of it on there website. Nothing shows up when you go to it. I think the costs would outweigh the benefits of the belt drive. Put that money towards a turbo or supercharger and not worry about the 5-10 something pounds you would save.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
He post under the name 2000srx on the ty forum.
http://www.totallyamaha.net/forums/showthread.php?t=32786&page=1&pp=10
Dyno Graph:http://www.totallyamaha.net/forums/showthread.php?t=34337&page=1&pp=10
Blade snowmobiles have direct drive no chain case. It has gears from engine to drive axel with brake on the drive axel
horkn
srx900 said:Blade snowmobiles have direct drive no chain case. It has gears from engine to drive axel with brake on the drive axel
I can't believe I forgot about the blade sleds. Too bad they were too expensive. They quit making those a while back unfortunately.
grader
i know that aftermarket conversion kits are out there but are quite pricey. if this setup was done at a factory level the cost would probably not be any higher than the chaincase setup.it would be lighter, cleaner and more efficient. to gain 2-4mph on top end is significant. as for the blade setup, the report by snowtech several years ago was not impressive, with the 800 polaris powered sled comparable to a 700 viper.
- 15K
