legend
just bought one what should be done to make it better .cluthing gearing intake pipes . thanks o7 gt
BombaPolaYama
It all depends on what you want it to do or what improvements you want to make - maybe ride it first to find out and then do some searching - there's tons of info here. You could start by reading the post on "Over the summer mods".
I think the first and possibly best mod is to upgrade the skis especially if you will go off trail or even ride on soft trails it needs a wider ski.
legend
50 off trail 50 on can you run a 15 inch wide track . can you run cr9 eks
BombaPolaYama
Sorry I don't understand your question. Are you asking if a 15" track is suitable for off trail? Or, if you can put a 15" track on a GT? If so, I thought it would already have a 15" track. I'm not familiar with the Phazer so i can't help ya there wrt off trail capabilities. As for the CR9EK, I believe you are asking about spark plugs. Again do a search, I remember some downside to using those.legend said:50 off trail 50 on can you run a 15 inch wide track . can you run cr9 eks
legend
all so looking for part number for red flap new style 09 010
BombaPolaYama
I give up.............legend said:all so looking for part number for red flap new style 09 010
07Nytro
- Dec 8, 2007
- Winnipeg, Mb
- None right now
pretty sure you cant fir a 15" wide track in a phazer, it sucks I know cause it really limits your aftermarket track selection
Jeffz
- Feb 3, 2010
- Cresco, Iowa
- 2008 Yamaha Nytro RTX 40th
2007 Phazer "RTX"
No, a 15" track will NOT fit your Phazer. Also, leave the stock plugs in. It won't make any significant difference in performance if you change them. Find the "Over the Summer Mods" thread and do some research. As for part numbers, go find them on an online OEM parts supplier, preferably one that sponsors this site.
legend
thanks . for the tunnel inclosure kit do you guys have a part number for it thank you.
Mr E
Jeffz said:No, a 15" track will NOT fit your Phazer. Also, leave the stock plugs in. It won't make any significant difference in performance if you change them. Find the "Over the Summer Mods" thread and do some research. As for part numbers, go find them on an online OEM parts supplier, preferably one that sponsors this site.
X2
kodak
hey legend check out schmidt bros motorsports they are sponsor of this site I believe cause I see there adds but good stuff for phaz and tunnel closer kit there and don,t need part numbers just call chris . hope this helps . guys on this site are really helpful be specific of what your looking for and you'll get an answer.
Ruckus
ugh
legend
will a rx1 secondairy fit and will it benafit the sled thanks .
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
legend said:will a rx1 secondairy fit and will it benafit the sled thanks .
Yes, but you will need to modify it a bit. Take a look at this post.
http://www.ty4stroke.com/viewtopic.php?t=101732
porkchop
legend said:thanks . for the tunnel inclosure kit do you guys have a part number for it thank you.
Why buy one, just make your own out of an 1/8th inch aluminum sheet- something like 12" X 24" I think mine was. Rivet it on.
Simple project, save some cash...
Camoplast 1 1/2" Freeride is the majorities choice for a track too.
