What Sequence
MtN_Rx1er
Cupar,Sask,Canada
Hey all, trying to sync the carbs on this 04 rx1 and cant find anything on what is the proper way the numbers 1,2,3,4 carbs run from, not sure if 1-4 start from clutch side to disc brake side, or the other way around.then ill know wich are the proper 1,2,3 sync screws in between them. can anyone specify on this picture i have found to use ? thanx
darv is right go left to right - i think it is #2 that is preset no adjustment so set #3 to #2 then #4 to #3 then #1 to #2
