dburrowes
- Jan 7, 2009
- Brooklin, Ontario, Canada
- 2015 Yamaha Viper LTX-SE
I installed a boost gauge on my hurricane 190kit. I love this turbo but was puzzled with the readings on the gauge. At idel, I am seeing a -5 to -6. At wide open throttle and 8900 rpm I am seeing +3. I was expecting to see 9lbs on the gauge but either that expectation is incorrect, I am connecting the gauge to the wrong location or something's wrong with my Turbo.
Thoughts?
Thoughts?
sneakattak88
where did you hook up?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
190 shouldn't be more than 6lbs max and 8600rpm according to Dave. I just talked to him last week about my afr #'s
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
You will see 6 pounds under good conditions. Mostly 5. You are reading vacuum at idle. What brand gauge?
dburrowes
- Jan 7, 2009
I bought a cheap dragon digital and I hooked it into the end of the 4 place t connector that my carbs are connected to. Most I saw was 3
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Do you trust that gauge?????? I don't know if I would........
petey_sx700
- Nov 17, 2013
- Central, WI
- 2017 Sidewinder LTX DX
2017 Viper STX DX 146
2013 Vector
2018 SRX 120
- West Central Wisconsin
In Dave's instructions I believe it says do not go over 6. When I first installed my sled ran in the 4 range so I talked to Dave and we added a washer to the waste gate actuator. Mine now reads 5 almost all open throttle pulls with 10.5 AFR. I have AEM gauges. Call Dave and he'll walk you through any changes. Also could check for exhaust leaks.
