sportster64
What brand and model sled lift do you guys use for these yammahas , apex and a nytro
I see some rated at 700 lbs. My guess is they would be really wobbly when pulling skids or anything That requires pulling and tugging on the sled ??
buddah
- Apr 14, 2003
- Wetmore, MI
- '17 Sidewinder B-TX LE
Most of the guys around here that work on sleds a lot use a lift table with a powered winch mounted to the ceiling........raise the sled up to working height and then lift whichever end you are going to work on........FWIW
CaptCaper
- Jan 1, 2007
- Northern N.H.
I have been using the Ezcart stand. You use a 1/2 drill to crank up the sled. Get the long track kit with it if you have a 136" or longer. I work all the time on it as well as my neighbors Attak and wifes Vector LTX..All kinds of work. Exhust donuts,oil changes,studding and Some of those damn Hyfax just don't want to come off easy do they. Banging so hard to get it going out the window..PIA...Lift/Stand works great...
T-Bone
jsjacks.com has some very good products
SSX600
- Feb 13, 2010
- Richland Center WI
- 2010 Nytro XTX, 1997 Mtn Max 600, 1998 SSX600, 1975 SM292F, 1987 Inviter
ohio chassis works is where I got mine from and works great.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
2016 Apex XTX
Ground up lifts in Sun Prairie Wi. has good lifts.
4strokeluvr111
- Aug 27, 2011
- NW Wisc.
24K miles
JS Jack with the air lift is some of the best money I've ever spent! Built like a tank but easy to move around.
- 19K
