what spark plug tool?
Ya have to take the bolts out holding them in place first before pulling them out on an Apex as I recall.
For installing the plugs, I use a piece of rubber or plastic tubing. I push the tubing over the end of the plug which allows you to hold onto the plug while you place it back into the deep well in the top of the engine. Twist the tubing and feel your way to get the plugs to start threading into the head. This will prevent the plugs from getting cross threaded. I also use a very small amount of an antisieze compund on the threads.
I couldn't pull them off after taking the bolt off ( my hand,arms are weak with age now) so I pryed a little while pulling and the caps came loose. I used the spark plug tool in the kit it worked fine.
