niko
Hi guys just wondering what type of socket and size do i use to remove the spark plugs on a apex?
niko.
also any tips i need to know?
niko.
favarcat
The spark plug tool that comes in the tool kit works fine.
niko
Sweet, thanks for that
) Those top plugs do you just pull them off to get to the plugs?
favarcat
Yes, they just pull off.
niko
thanks for that.
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
Ya have to take the bolts out holding them in place first before pulling them out on an Apex as I recall.
RX1Jim
For installing the plugs, I use a piece of rubber or plastic tubing. I push the tubing over the end of the plug which allows you to hold onto the plug while you place it back into the deep well in the top of the engine. Twist the tubing and feel your way to get the plugs to start threading into the head. This will prevent the plugs from getting cross threaded. I also use a very small amount of an antisieze compund on the threads.
niko
wow, now that's thinking, I'll remember that when i Change them over
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
I couldn't pull them off after taking the bolt off ( my hand,arms are weak with age now) so I pryed a little while pulling and the caps came loose. I used the spark plug tool in the kit it worked fine.
