2005 RX1 Mountain Dan
- Dec 31, 2018
- grandjunction,co.
- 2005 Yamaha RX1 Mountain
This will be my first storage summer. What do you folks recommend?
In the Fall I meant sorry, fresh gas next Fall when you take it out again.Park it with minimal amount of fuel in it and top it up with a fresh tank in the spring.
‘03 Rx-1 Mtn with over 22,000kms bought from new and I’ve never even done that much with it lol, but it’s a good idea.
If it were a 2-stroke you might want to fog it. I have 2 excellent running ‘95 Vmax-4’s and again, I’ve never even done that much with them for storage.
Do you have non ethanol fuel available in your area?I prefer this to using junk ethanol gas with additives..have had issues with treated ethanol fuel but never any issues with non ethanol&it seems to keep for a much longer time.ive. had ethanol fuel go bad in 2 months time.This will be my first storage summer. What do you folks recommend?
Never heard of it? Where do you get it
I also like to remove my belt as it keeps the clutches from getting oxidized where the belt sits,I don't add anything to non ethanol fuel&haven't had any fuel problems or residue etc I also use an air compressor&blow all of the dirt,pebbles etc out of the belly pan,running boards etc then polish all aluminum running boards,tunnel extension etc if your using a high quality aluminum polish it goes quickly &seems to keep them from oxidizing over the summer/fall monthsI guess it depends how fussy you are about your sled, me personally, I am very fussy doing the end of season summer storage prep, fuel stabilizer, double up for longer sitting times run your engine to make sure it gets into the throttle bodies or carbs, grease everything that has a grease nipple and spin your idler wheels by hand with track elevated, under coat everything including your front a arms and shocks and ski mounts, all your skid, I use rust check green can, under the hood clean and wipe any dirt or salt residue you can see, spray your wires and connectors and plug in's with under coating also mice hate it plus it keeps your wires from getting moisture and corrosion and ozone hardening, spray armor all on all your rubber hoses you can get at including the ones at the back of the tunnel, clean your clutches and blow them out, air filter screen, apply some leather care to your seat, put some sticky mouse traps on top of your track and smaller ones inside cab, some fog there engines, and change their oil and filter but I do that in the fall prep, give her a good coat of wax, I might of missed a few things but all I can think of for now, hope this helps
I like doing every thing I can to protect my sled and keep it clean, they hold up way better, harder for some one to Nickle and Dime you if you decide to sell, my last sled my buddy bought it was absolutely mint, we ride together from time to time, It brings tears to my eye's the way he beats on it and never cleans anything.^ I like the way you think.
We're the type of guys who's sleds have 8,000 miles and look like they have 80.
Just like when I sold my 1998 MXZ this winter, and when I opened the trailer door, the buyers first words were, "damn this thing is CLEAN!"
Some idiots couldn't get someone to call their 2018 sled clean.
