mcamzr
Well here in MI our season is over so it is time to think about what mods to do over the summer. I'd love to here what everyone has planned and maybe we can all share some ideas. I myself will be adding a mountaintech tunnel cooler and work on polishing the tunnel for sure but maybe more.
Sledguy89
136 extension, 1.5 intense, header, power commander, intake, new front suspension, re gearing, shock revalving, an lots of powder coating. That will be my off season
Install Star Suspension kit, and reinstall the swaybar.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Mods for summer.
hindle exhauste
airbox mod
pcv with auto tune
lake effect riser
oft relocation kit
clutch kit
Heavier rear suspension springs
wrp seat mod
hindle exhauste
airbox mod
pcv with auto tune
lake effect riser
oft relocation kit
clutch kit
wrp seat mod
Mods this summer
Turbo install
Pro RMK rear suspension
162 track
Shock rebuild and revolves
Cooped doughnut
Rad delete
Think Thats it
Turbo install
162 track
Cooped doughnut
Rad delete
Think Thats it
jonnytro
Haveing the head sent out to be cut. I was wonderong if any1 new if they make a cam for kit.
crossroadz
- Oct 24, 2012
- Munster, IN
- 2011 Apex XTX
So far for my 2012 XTX:
1. OFT relocator
2. Star suspension with center shock revalve and new spring
3. Tall windshield with side extensions
4. Tuner skis with 6" and 2" carbides
5. Studs 1.325"
6. Yamaha shop manual
7. Oilite bushings
8. New subframe because I bent mine on a railroad. Hopefully that's it but I suspect I may need new a arms.
9. Auxiliary cooler
10. IP vent
11. Snowmobile lift so I can put all this stuff on
This will keep me busy but tweaking on my sled is half the fun.
1. OFT relocator
5. Studs 1.325"
7. Oilite bushings
9. Auxiliary cooler
10. IP vent
Dodge Ram
Summer mods
OFT relocator
Star suspension?
All the shocks sent out to be rebuilt.
Clip the track (full)
Frog skin the covers. Trying to reduce Belt temps. 2 belts this season is killing the wallet.
Not a mod but change all the fluids. Amsoil everything.
Not a mod but, try to fix the 500 saber cat the kid
drove into the tree with.
OFT relocator
Star suspension?
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Re: Summer mods
How much are belts by you?????
Dodge Ram said:OFT relocator
Star suspension?
Not a mod but, try to fix the 500 saber cat the kiddrove into the tree with.
yamahahaapex
MBRP exhaust, top lid air box mod
mx1500
i went through 4 belts this season... ugh. new clutch for me and maybe a turbo
yam429
- Jan 18, 2009
- Saint Michael, MN
- 2009 Nytro XTX, 2010 Vector LTX, 1981 SRX 440, 1989 Inviter, 1991 Snosport, 2004 Snowhawk
- Saint Michael
I'm hoping to add an OFT oil tank after seeing that the top mounting bracket is broke on my stock one also would like to add the Mountaintech shorty skid plate. I also need to remove the front shock in the skid and have Star Suspension add the spacer to it and possibly revalve it.
mcamzr
Re: Summer mods
How do you go about cutting the track to clip it?
Star suspension?
Dodge Ram
Re: Summer mods
NO cutting. Buy a clip tool and put new clips on. I am not studding it. Friend has an air clipper to make things easier.
Belts this way i don't rememeber.
mcamzr said:Dodge Ram said:OFT relocator
Star suspension?
Supa Dexta
He likely meant the windows, as some tracks only have every 3rd cut out.
- 12K
- 12K
