Michigandir
- Nov 28, 2014
- Michigan
- 2013 Yamaha nytro rtx
Need to buy larger idler wheels to save (hyfax) sliders. Are they any options besides excell and schmidt bros. Is one better than the other? What are you using? How many wheels do I need, I see they sell them in kits and individually?
sloan188
- Nov 28, 2012
- Vaudreuil, QC
- 2005 Polaris Fusion 900
2009 Nytro XTX
2010 Ski Doo GSX LE 1200
I'm running 8 excel wheels. There are other options that will be cheaper...if you search you will find the wheel size (5.25" I think)...the cheapest solution will probably come with cheap bearings which you can run or upgrade to NTN purchased separately. Again searching you can find what others have used; polaris, kimpex, skidoo all come to mind. The excel aren't cheap but come with NTN bearing and are direct swaps. If you want to use the existing hardware you will want to ensure the bearing race is correct size (12.5mm I think...a search will confirm). If I recall, 6 wheels are stock and I added two which also required mounting hw.
04nightfire
- Jan 30, 2014
- Orillia, ontario
- 2020 Sidewinder L-TX LE
I went to the polaris dealer and grabbed four of their idler wheels. I also put the "white" sliders on this year. This combo has shown little to no wear so far
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
nightfire, can you elaborate on "white" sliders, are these still just plastic with different melt and better wear??
04nightfire
- Jan 30, 2014
- Orillia, ontario
They are the standard UHMW as far as I know. For whatever reason they seem to last longer than the standard black ones.nightfire, can you elaborate on "white" sliders, are these still just plastic with different melt and better wear??
mp5
- Feb 14, 2011
- New Brunswick, Canada
- 09 Nytro XTX
I installed 6 ski doo wheels on mine...and all new rebuildable wheels on rest of skid...also new Dupont sliders. I had to slightly machine the inner front idler mounts to fit between rails as the ski doo wheel bearings are thicker than the oem Yamaha bearings. If I were to do it again I would go w the Excell Kit as they come w all the direct mounting hardware...and no machining of aluminum mounts to make fit
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My yamaha dealer had the 135mm wheels on the shelf. An exact match to the stock 130mm wheels.
DMCTurbo
- Nov 12, 2005
Since I installed the 135mm wheels and white sliders(made by kimpex) I have had no wear at all.
fourload
Put the duponts on and save the wheels for later if you need them. 400 miles on my duponts some on marginal snow and no wear at all. Last year I went through a set of stock sliders in 350 miles!! Also make sure your track is not to tight. Mine hangs 3/4 of an inch . The track clips run very cool and the sled rolls much easier with the duponts also!!
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Over 1500 miles on my 1st set of duponts with stock wheels. Ice scratchers a must for the hard trails.
Pete
Pete
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
6 Excel wheels, same sliders for 5000 km's.
Yama 1000
- Sep 2, 2011
- Rochester ny
- 2015 viper LTX DX
Excel 6 wheels. With 121" track I had 3700 miles and sliders still could probably go another 2000 miles. Now I have a 136" with backcountry 1.75 track . After 800 miles the slider are showing hardly any wear. Snow conditions have been some light and some fluff.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Excell wheels with white sliders.
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
6 Excell wheel kit + DuPont sliders, no wear yet in 1200 miles.
Michigandir
- Nov 28, 2014
- Michigan
Thanks everyone. I ordered the excell idlers. I just started with 4 Not the 6 wheel kit. I hope that's ok. Where do you get the white sliders at? Maybe dupont next year. And why does yamaha want the track so tight? 1.18 to 1.38 at 22 lbs. I'm thinking it should looser than that.
