shanksyamaha
I just put the seals back on my clutch side jack shaft and drive shaft bearings after repacking them with grease for this season. and I was gunna clean my clutches.... Whats everyone using to clean your sheeve faces.??? Some use brake cleaner and others say absolutely not... Whats everyone doing to get them sheeves to bite the belt for the best jump off the line.....
BBBBRRRRAAAAAAaaaaaaPPPppppp
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Hot soapy water and rinse.
Shootinstick
Acetone
YammiMoose
- Mar 18, 2004
- In a place where it SNOWS every day
shanksyamaha said:I just put the seals back on my clutch side jack shaft and drive shaft bearings after repacking them with grease for this season. and I was gunna clean my clutches.... Whats everyone using to clean your sheeve faces.??? Some use brake cleaner and others say absolutely not... Whats everyone doing to get them sheeves to bite the belt for the best jump off the line.....
I remember reading somewhere that if you use anything other than Hot Soapy water it will go into the sheeves and come out while riding.
-Moose
Compressed air first, as long as black dust comes out, then Scotch Brite pad medium or heavy.
woolyviper
- Mar 24, 2006
- hibbing,mn
- 2009 Yamaha Phazer RTX
put it in that white thing in the kitchen that has dishes in it.
schmeg
Medium scotchbright (brown) and alcohol, followed by a cold water rinse and paper towel dry.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
use yamaha contact clearner it leaves no residue on cluthes and it is cheap there orther brands no name but make sure it is contact cleaner
zackn291
hot soapy water. and blow all that black dust out with an air compressor
apltx08
Spray Nine/Simple Green, Green Scothbrite with BOILING hot water to open the aluminum pores to release all the CRAP, rinse & scrub...then rinse! and rinse! and wipe it good and DRY, also wash your BELT with dish washing soap in hot water and rinse and rinse and sponge dry with a clean cloth.
fourload
Acetone
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
Brakecleaner.
bashley
I did that one time with my Bronco's air intake plenum. Couldn't get in to it real well to clean it, so in the dishwasher it went. Then came the truth behind the old saying " Easier to ask for forgiveness than permission".
Did a nice job on the plenum but took forever to get the black color and smell out of that thing.
KbxSrx
woolyviper said:![]()
BWAAAAAAAAAAAHAHAHAHAHAAAA breathe breathe hehehe
shanksyamaha
HUM.... Lots of different answers here... I used hot water and dish soap on the belt when I got it so its ready. Just lots of mixed opinions on the clutch sheeves..
- 11K
