TIMSMXZ
thinken about an ulmer clutch kit for my 07, the sled is fast out of the hole already, what are the gains from the kit?
RIGIDONE
more pull, and way less backshifting.. you will actually be able to use your brake. i feel like i have much better control going into a corner..
RayKnobs
I just put one in mine Tim. If you can hold out till the snow falls we can meet up and test it side by side with your stock clutch.
I keep my sled in Williamson
TIMSMXZ
ok that sounds good.
On mine with stock clutching and slightly worn belt I was always banging the revlimiter.Ulmer kit took care of that along with what these guys have said already.I put Freeride on close to same time as clutch kit so I am not positive but I believe you will also gain some top speed.
- 7K
