Where can I get a 4th wheel kit?
The axle is bigger but I believe it's the same suspension, Mine isn't an LTX so I think all the short track suspensions are the same foe all the monoshock's . What method are guys using to cut the tubes ??
I would use a table saw. Most saws today use a carbide blade. That will cut thru Aluminum easily and give a very straight cut. Then sand the burrs off.
I use a copper tube pipe cutter. It has a roller and a cutting wheel. Clamp it on and spin it round and round and round...... It takes quite a few turns but it gives you a straight cut.
