unlited
- Apr 19, 2015
- Setermoen
- Norway
- Nytro MTX 163" 240 Turbo 2010
Nytro MTX 153" 190 Turbo 2013
Nytro MTX 153" Supercharged 240 hp 2012.
can some one told me where to fine 5v on my nytro? Need it to the map sensor / boost sensor, to the powercommander
Thx
Thx
sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
Clutch side, should be velcroed to rad fan shroud on top.
unlited
- Apr 19, 2015
- Setermoen
- Norway
I will check it out. Do you have a picture where?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
unlited
- Apr 19, 2015
- Setermoen
- Norway
Yes how to install the pcv its okey, but i need 5v to the map sensor / boost sensor i want to install. Where to find that on the snowmobile?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Do you want to know where the boost sensor goes. I see your from across the pond. The language is coming across a little different. You can install an O2 sensor for the autotune function, but that requires the autotune module. A map you just upload from a laptop. Hope this helps. If not keep asking we will get to bottom of it eventually.
unlited
- Apr 19, 2015
- Setermoen
- Norway
I need to know where to find 5v to e map sensor, the snowmobile has 12v but dynojet say i need 5v to the sensor, is it 5v on the thortel posision sensor? This is that it need to install
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Not sure on that one. You must be running a different setup. I'm just running PCV, huricahur map, full Hindle exhaust, air box mod with proper clutching. Not sure how you are setup, normally dynojets are plug and play unless you add the autotune box.
unlited
- Apr 19, 2015
- Setermoen
- Norway
Do you have a supercharged nytro? Hors power? Boost?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Stock motor. No super charger, no Turbo. Just PCV, exhaust, and air box mod.
unlited
- Apr 19, 2015
- Setermoen
- Norway
Any?
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Any? What?
