nos
- Oct 19, 2013
- Iowa
- Nytro
Broue
- Feb 28, 2015
- FX Nytro XTX 2009,
Factory race front end
Star suspension relocation kit and revalve
Ski Doo #503192064 center spring
135 mm idler wheels
Oilite bushings
Grizz steering relocator
Tuner ski : 6 ''carbides,
WRP seat
Vector gauge
Custom Taillight
LinQ tank
Sno Sport 1990
Ski Doo Tundra R 1998
remove the left and to cover, on the left side, there's a quick connect, you can't miss it
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
On my 2010 nytro I found the connector in a rubber boot on the right side of the headlight pod. There is a plug in the end of the connector with no wires coming out of it. Remove the dummy plug and plug in the accessory plug.
Yannie
- Jan 5, 2014
- Winnipeg
- 2010 Yamaha Nytro RTX
Left side (brake side) remove hood and side panel the connector should be along the rad, white plug 2 prong.
Dr. FeeLGooD
I went straight to the battery with a fused link. That way I can use it without the sled running.
nos
- Oct 19, 2013
- Iowa
- Nytro
I've looked in the locations mentioned and I am just not finding the plugs described. If anyone can get a picture it would be much appreciated!
shadow44
Left side at rad for 09 and newer....08 has to be hard wired as it doesn't come with the plug.
You probably couldn't find it because you have an 08 model!
DSimps10
- Oct 10, 2014
- Oxford Michigan
- 14 Nytro XTX
I got a plug from work and just ran a power and ground to the battery with a fuse on the power side so i can pull it in the off season and if i don't ride for a while. not the cleanest looking setup but it works for the GPS and phone if needed.
