Yamanator
- May 5, 2003
- Oxford,Mi
- 2017 Sidewinder LTX LE
Hey guys, just realized I don't have a plug in for my heated shield on my 09 Nytro. Can someone please tell me or show a picture of the 2 wires you are supposed to connect too? I want to make sure that it only has power when the key is on, hopefully there is something right in the handle bars to tie into because I have a 2 inch riser and it would be an easy install. Thanks for the help in advance guys....... LET IT SNOW.......
yox185
There is a plug for the accessory outlet on the 09's. It's on the left hand up high behind radiator.
ice-age
I wired mine to the battery. It works great.
yamariv
ice-age said:I wired mine to the battery. It works great.
Hey Ice-Age, did you wire it directly to the battery without a fuse? My dealer says you don't need a fuse if its direct to the battery but that makes me a bit worried.
natedogg3
Rockmeister sells a power supply that allows you to plug in multiple things and its plug and play on most models.
check it out!! http://www.yamaheater.com/Products.php
sheetwright
No fuse needed. I bought a helmet kit from my yamaha dealer and it has direct wire hook ups for the battery
jb_008
- May 21, 2012
- Sault Ste. Marie, On
- Yamaha Nytro RTX SE 09
Here is a step by step on putting in the 12v socket which you can then plug in the helmet adapter.
http://www.ty4stroke.com/viewtopic.php? ... c&start=15
yamariv
Thanks gents, I'll just install it with no fuse then.
