Which bogey wheel?
He needs the rear most idler. Use the new spoked Yamaha wheel with replaceable bearings, part number SMA-8HF38-20-BK. It's used on the newer sleds.
Yes, the larger wheel is for the rear. However, the non oem wheel will be different than the other outer rear wheel on your sled now. Rear Yamaha wheels have a specific look, so you may want to replace both outer wheels at the same time, if you buy non oem wheels.
i bought 2 used 7" rear idler wheels from travis for i think 15$ each. plain black
