Honk
sled toyz
Capt.Storm
Yep..good service...look good!Honk said:sled toyz
Putting mine in today.
smalltownpower
nice thing about sled toyz is you get a order number, and constantly emailed purchase status's. so you know exactly when its shipped, or when your order is confirmed. got my copper donuts, ready to put in the phazer.
Capt.Storm
What a pain working on the exhaust!
For anybody putting in new y pipes..don't bolt the flex pipes to the motor first..you won't get the y pipes in.
So after doing it the right way I went to put the muffler on..what a pain to get the muffler pipes hooked back to the y pipes.
First you have to be careful not to booger up the gaskets in the muffler end of the pipe..and they don't just slide back to gather.
I had to hook a strap and try pulling them together and heat the joint with map gas the sameas I had to take it apart.still don't have it in far enough..I'm bring home another map torch tomorrow so I can heat both pipes good.
What B.S.
What B.S.
Capt.Storm
Acedog1
I bought the Bender Racing donuts...look the same as stock but they claim they will handle anything. Anybody run them?? We don't have any snow where I'm at so I haven't run it yet.
ViperTurboPete
- Mar 25, 2005
- Sudbury, Ontario
- 2015 Viper XTX LE MPI Turbo
2022 Expedition Extreme 850
Can you simply change the donuts without changing the gaskets at the engine block?
Capt.Storm
I used the same gasket..seemed fine.
Getting the donuts out with out backing off the pipes might not be able to be done.
I had to change y pipes so I didn't try.
On mine I would have had to take the 4 bolts out that hold the muffler in place to move it all back..no way would my y pipes had slid back into the muffler pipe to get the donuts out.
You might be able to leave the all pipes alone and take some motor mounts off and rock the motor a little..didn't try it.
To get new y pipes in you have to take the 4 flex pipes off.
Maineland
I went with copper donuts just had to back off the Y pipe bolts and they slid back just the right amount to get the flex pipes out. I also used the same engine gasket. The job went really well even though it was my first time thanks to this TY 4 stroke.
99669apex
Do we need to have another discussion on exhaust donuts again? Really?
I was looking over some of my prior postings and found this response that I had on December 11, 2011 to the same subject:
I don’t want to rain on anyone’s parade here, but why do we buy Yamaha snowmobiles? Engine life, quality engineering and all around durability to name a few. I’ve read all the postings about copper exhaust donuts like the rest of us, and I was ready to pull the trigger on a set for my Apex, then reality hit me. Yamaha engineers do not cut corners! They also don’t follow trends.
If Yamaha engineers believed that copper exhaust donuts were a better option, they would have come stock on our sleds. Think about it.
Capt.Storm
They might not have!
Cost!
Heck they gave us wheels that you could not change out the bearings.
Stupid plastic screws all over the place.
Bushings in the a arms that you can't grease and don't last long.
Steering components that wear out fast.
I live yammi but don't lecture me my friend.
Those 5mm hex head bolts are stupid.
Cost!
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
RX1MPete said:Can you simply change the donuts without changing the gaskets at the engine block?
The gasket at the block is steel if I recall and is reusable. You may be able to compress the flex pipes a little to get the donuts in there without taking the flex pipes off. See the second last picture in grizztracks post: http://www.ty4stroke.com/viewtopic.php?t=90978
99669apex
Maineland
cost is not a big deal only 2 dollars more than oem
Capt.Storm
if you get them from sled toyz ...others are double I'm told over OEM.Maineland said:cost is not a big deal only 2 dollars more than oem
