Cubby
- Dec 14, 2009
- South of Winnipeg, Manitoba CANADA
- 2015 Ski Doo 900 ACE Renegade Adrenaline
2007 Yamaha Phazer GT
I purchased the updated fuel pump relay. According to the printout from my dealer, the fuel pump relay looked to the be the 3rd from the left. However there are 2 banks of relays (top and bottom) I thought it was the top row but when I removed that relay I could still hear the fuel pump prime. Which one do I need to replace?
I have attached a pic of he relays on my sled.
Thanks in advance!
Thanks in advance!
Ruggybuggy
- Sep 1, 2013
- Kenora, NWOnt, Canada
- 2007 Phazer FX 144
You can't go by location in the manual. They can be easily switched around. Go to the wiring diagram and check out the wiring colours and identify that way.
on mine,it was the hardest one to get to
Cubby
- Dec 14, 2009
Thanks guys. I guess i need to spend some time in the garage this morning. And its -30 to boot!
i bought a new venture this year and i installed that new relay in the showroom,i never had an issue all season,5000 km so i guess it works
Ruggybuggy
- Sep 1, 2013
If it helps it's usually the first or second relay towards the front on the top row.
Cubby
- Dec 14, 2009
I tested the 2nd and 3rd one and no luck. I'll try the first.
Ruggybuggy
- Sep 1, 2013
Look for red with green tracer, red with white tracer, red with blue tracer and blue with red tracer.
Cubby
- Dec 14, 2009
It was the relay closest to the front of the sled. Of course the last one I tried. To verify i would unplug each relay one at a time and see if the fuel pump primed.
All good to go out this afternoon.
