white secondary spring for apex
f7lee
sylvan beach, ny
I know this has been beat too death on here but would like to ask if the white spring works well with everything being stock,helix gearing,primary spring,weights and 144 studs on an 06 apex rtx. Where will i feel the difference the most. By the way sled has reverse also. Thanks Lee! ;)!
Ya it works, it slows the upshift. It works even better if your a bigger guy, you'll notice a differance.
SharkAttak said:
on my Attak with the Ulmer clutch kit i run the white secondary spring at 3-3 work's minty
3-3 ? Is it a little slugish in the trails? Any slipping? What kind of conditions do you run in?
not sluggish at all, no slipping, what spring do you run?
It will work, but you need studs.
Ulmers Stage 2 kit, I was going to try the White Spring but I went for the Stage 2 kit instead. A buddy tried the 3-3 set up for radar and it worked good but he said in the trails it was a little slugish.
The white spring @ 60 seems to backshift a little better than the silver spring @80 or 90 but the silver spring definately upshifts harder and gives me better mph on ice and hardpack with my ulmer stage 2. RPM's are a little higher with the white spring too.
White spring=higher rpms, quicker backshift, but acceleration falls off after 60mph.
I recently changed from the silver spring to the white and found better acceleration throughout and seems snappier on the trail. To date my highest speed on the dreamometer was 125 on plowed road. My friend has the same year RTX with Woodys power up kit and I weigh maybe 10-15 lbs heavier and before the spring change he always beat me. Now everything is same but white spring and cr10s and I've beaten him 3 times out of 5 and the other 2 I would dial him back in and he hit 104 and I hit 111 in the same distance. One thing I may change is wrapping the silver at 80 or 90 I believe mine was at 70. Anyone else with a Woodys power up kit know what its wrapped at? Mark :Rockon:
