Maybe I'm misunderstanding the thread here, or at least the terminology, but if your steering is too heavy, it sounds like you're adjusting wrong. To me "heavy" steering means way too much ski pressure, hard to turn, darts like hell. If that's the case, you don't want to pull up on your limiter straps and back off on the front skid spring! That puts more weight on the springs because the center of the sled is no longer supporting it. You want to loosen the straps and add preload to that front skid spring. This will raise the center of the sled, which will take weight off the front of the skis and relieve pressure. I would think that with those slydog skis that you could run less ski pressure than stock and still have plenty of bite in the skis.
