sprintcat
- Jan 13, 2009
- Rumford Rhode Island
- Nytro xtx
I herd that the sly dog phazer grommets / rubbers worked good on the pilots. is this true ? and if so witch way do you mount them ? the tall part to the front or the short? thanks
ShootToThrill
bagadonitz said:I try and ride mostly off trail so I put 4" Doo carbides (they were the easiest thing to get where I am) down the center and sides. When I wear out the center onces, are the shapers any advantage to me? What length (4", 6" 7.5") should I get. 6.9's on a 144" stretched RTX with cut + shimmed ZX rubbers.
They tend to push a little in loose trail conditions. The shapers make them more aggressive but don't add much if any steering effort. I would get the 7.5. But off trail try the 4in they are cheaper. For the small amount time you are on the trails the few extra dollars will be worth it.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
sprintcat said:I herd that the sly dog phazer grommets / rubbers worked good on the pilots. is this true ? and if so witch way do you mount them ? the tall part to the front or the short? thanks![]()
I used the skidoo rubber stoppers which need to be rotated so that the tall side is to the rear of the ski. Read my post and go to the photobucket link for more pictures. http://www.ty4stroke.com/viewtopic.php?t=84889
Left side Nytro spindle:
marsh14
Tall part to the back on the slydogs.
- 18K
- 6K
