DaveB
- Oct 17, 2012
Wondering whose rollover valve system this is. Was installed on my sled when I got it. Appears to be all plug and play. Pulling the tether kills the motor and sends 12v to the plug (I tested) but the valve doesn't do anything. I took it off and sprayed WD40 in it and hit it with 13v a few times on the bench and all it will do is move about 2mm inside. It appears to be a sealed unit....so I can't really pull it apart to try to clean it. Wonder where I can get a replacement?
Pictures are of the valve from two angles, a shot of the tether and switch, and a shot of the connector to the valve (valve removed).
s1d3w1nd3r1480
Contact Four Stroke Solutions or OFT racing. Judging by the tether it is a kit from Four Stoke Solutions. Either way all the kits use the same valve, the differences in the kits lay in the circuitry, tether, and wiring harness. Either company should be able to help you out to get the part you need.
Mtnviper
Vendor
DaveB,
That is one of mine. I have replacement valves in stock and can get you going again.
Either PM or e-mail at fourstrokesolutionsllc@hotmail.com will work.
Bill
Bill
- 43K
