twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Just picked up a new 2025 LTX LE EPS last Friday. While I was working on my 17 LTX SE, I was comparing the idler wheels. I found that the small idler wheels on the 2025 are only 5.5" while the 2017 are 5.63". Does anyone know why they would have gone to smaller idler wheels on the 2020+? I realize that the rails are different but are the mounts mounted lower than the 17-19 (kind of like what they did with the Mono II skid for the Apex)?
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
check same for Arttic Cat on their sleds to see if its their little trick to make sure they run better than the winders.. Or is to sell more Hy-Fax or is to slow top speed, IDK but seems like not normal to me.. Good investigation….
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
The newer Arctic Cats use the same 5.5" wheels.check same for Arttic Cat on their sleds to see if its their little trick to make sure they run better than the winders.. Or is to sell more Hy-Fax or is to slow top speed, IDK but seems like not normal to me.. Good investigation….
This is the 5.5" wheel.
https://shop.arcticcat.com/4604-355#/s/ARC//4604-355//1/y
This is the 5.63" wheel that was used through 2018 for the Procross chassis.
5.63-in Idler Wheel (Black)
This Idler Wheel keeps your track in place while reducing potential friction on the hyfax. It measures 5.63-in for outer diameter, while it measures .787-in for inner diameter.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Anyone else have any input?
timmyz06
- Feb 28, 2018
- MTL
- switchback assault
i can tell you, my 19 ZR RR have the 5.5 idler wheels! To my understanding, its that way for the 19 and plus+!
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I understand that is the way it is for those year. I am asking WHY they went to smaller wheels.i can tell you, my 19 ZR RR have the 5.5 idler wheels! To my understanding, its that way for the 19 and plus+!
idontknowjack
- Mar 22, 2020
- SW Ontario
- '20 SRX
I would think because of the silent track.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Nope. They have ALL had the silent track since 2017. I think even my 2015 Viper had the silent track.I would think because of the silent track.
Simplespeed
- Jan 8, 2022
Sure would be nice to ask the Arctic Engineer why he made that change and whats the real reason for this change… Maybe the question should be does anyone know anyone that worked for Arctic Cat engineering department? Maybe they could answer this question.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
I will likely have to measure how far past the hyfax on the new 2025 sled that the 5.5" wheels sit and then when it is time to replace the hyfax on my 2017, measure how far new 5.63" wheels sit past the hyfax on that one.Sure would be nice to ask the Arctic Engineer why he made that change and whats the real reason for this change… Maybe the question should be does anyone know anyone that worked for Arctic Cat engineering department? Maybe they could answer this question.
I was considering running Ski-Doo 147mm wheels on the 2017 once I need to replace my hyfax. Those would be 4mm larger than the stock 5.63" wheels. They would be 7.3mm larger than the 5.5" wheels on the 2025 which is likely too much if the smaller wheels mount lower.
I just found that the wheel mounts use different part #'s between the 2017 & 2025.
2017 uses Yamaha # 8JP-G7419-10-00 (Arctic Cat # 3604-899)
2025 uses Yamaha # 8JP-G7419-20-00 (Arctic Cat # 4604-652)
I guess I should remove a mount off each sled and compare them as well. It is possible that they hold the 5.5" wheels lower on the newer ones. Yamaha did this on the Apex/Vector when they went to the Mono II skid. They used the same wheels but used mounts that lowered the wheels.
Simplespeed
- Jan 8, 2022
On the my 2017 vs 2024 I have noticed that the sled does roll more free but I thought it was due to more miles on the 2017 . Now that I got 700 miles on 2024 this condition has not changed. Yes I agree that 7.3 is way too much if thats the case. If I remember right on my Apex I used a wheel that was either 1/8” or 3/16” larger than stock and it was night and day better on 2006 Apex Gt at the time… Of course that motor had way more engine braking than these 998. So getting that suspension to roll was important to get the gas mileage I was after and to eliminate hy-fax wear in low snow conditions…
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Despite part number change I am not aware of any dimensional differences. I put a 17 and 22 mount back to back and they match up. 17 mount fits the 22 and 24 rails i have here. I have been selling the 5.62 and 147mm wheels for 19+ with no issues.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
That's good to know. Thanks.Despite part number change I am not aware of any dimensional differences. I put a 17 and 22 mount back to back and they match up. 17 mount fits the 22 and 24 rails i have here. I have been selling the 5.62 and 147mm wheels for 19+ with no issues.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
When drag racing and speed running, we'd take all the wheels completely off, even moved the back wheels upwards on the rails to ride strictly on the hyfax which proved to be faster than running on any wheels. This of course proved the Hyfax wasn't hot and sticking slowing things down. We used to be able to use slide lube too however. Running the track over the wheels slowed the machine down every time. Wheels and rollers were only used for asphalt and grass sleds in dry summer conditions.... Just saying.
Perhaps Duponts are in order for some of you worried about a few thousand's in wheel diameter and way overthinking it.
twyztid
- Feb 14, 2011
- Middleville, MI
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
Trail sleds obviously need wheels and a number of people have stated that the 2019+ idler wheels don't last. I started looking into the wheels and found they were smaller and was looking for a reason.When drag racing and speed running, we'd take all the wheels completely off, even moved the back wheels upwards on the rails to ride strictly on the hyfax which proved to be faster than running on any wheels. This of course proved the Hyfax wasn't hot and sticking slowing things down. We used to be able to use slide lube too however. Running the track over the wheels slowed the machine down every time. Wheels and rollers were only used for asphalt and grass sleds in dry summer conditions.... Just saying.
I have Duponts on my 2017 but they are likely not worth the cost on these sleds vs the Apex or Vector. In addition, if the 19+ style idler wheels need to be replaced, there is no reason to stay with the smaller 5.5" diameter.
