bigreis
- Jul 10, 2011
- Central Minnesota
- 2007 Apex RTX
2009 Nytro XTX
Any good welder would be able to repair it to like new condition in about a 20 minutes. If you were closer, I would do it for you for $20. A new rail is going to cost you a lot more.
sherlock29
just get it welded. no brainer really... you could put that spacer back on real tight and keep on running really... and replace when you get the new one. I have welds/plates welded onto mine... rails are not that strong... i've bent them back into shape with a couple big wrenchs before.
I was thinking of tighting it too? I ordered parts, I have take the skid out to put that darn bolt in. Ugh!
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
viper7mi said:I was thinking of tighting it too? I ordered parts, I have take the skid out to put that darn bolt in. Ugh!
Why do you think that you have to take the skid out to put that bolt in? I would think that if you loosen the track tension you should be able to get it in just fine. Am I missing something?
It's the bolt by the w arm, the arm is in the way I think? Can I get that second wheel bolt out without taking the skid out?
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
Mmmm....not sure since I have an Apex which has a different suspension than the Attak. Perhaps an Attak owner can confirm.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
20 min to take the skid out and 30 min to put it back in and tension track. Instead of removing the pivot arm lower bolts and trying to get them back in.
sherlock29
disconnect limiter strap, loosen track, remove 2 rear bolts in tunnel. lift back of sled and push suspension forward enough that arm clears bolt... suspension does not have to come out....
Sounds good
