almond1000
- Jan 20, 2008
- North Fond du lac, Wi.
- 2017 sidewinder 2011 vector gt 2010 fx nytro 2009 vector gt
Does anyone know if an 07 phazer primary clutch fit an 08 fx nytro? I know weights and spring is different but wonder if the taper and diameter are the same. My nytro primary has some cracks and ran across a nice low mile phazer primary really reasonable
radianguy
- Jan 1, 2007
Not sure if phazer clutch is same as nytro clutch but are you sure your clutch is cracked or is it just casting marks?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Yes it will fit. Only difference is no set screws on the weight pins on the pz clutch.
almond1000
- Jan 20, 2008
Yes, it is cracked, i was a die caster for 20 years, i know a casting line from a crack believe me. i did find a decent clutch i am going to put on, i was also going to do the 14.5 rollers and y-p-y spring. I found the roller part number but i see 2 different y-p-y springs, looks like a long and a short, does anyone know which to use?
livewire_101proof
You will want the spring for long cover, as long as u use the outer cover from your nytro clutch, I am pretty sure the Phazer had a short cover though, so if u use the cover coming with the Phazer clutch u would need the short spring. If nobody else knows for sure I can check for you in the next couple days as I have a Phazer and a nytro.
The smaller rollers are easy enough to find used also as that came in slot of the 2 stroke vipers, probably some other models also
almond1000
- Jan 20, 2008
Thanks, ill get the longer spring, i ended up finding a clutch off of nytro so im just planning on the 14.5 rollers and the y-p-y spring
