Rye_Guy78
- Oct 31, 2014
- 2015 SR Viper LTX SE
Need some help!! I have a blown motor in my 15 Viper, I have a line on a 09 Nytro motor, I know it’s the same motor but will it work in the viper? Thought there was a post on this already but can’t find anything. Thanks
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
It'll drop in, grizz did this along with the yamaha electronics. Dropped right in, the engine did. Hopefully he chimes in
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
it fits, i had nytro engine in mine first year 2016 becasue i had turbo.
yamakazie
Engine itself is identical. Plug and play. When Grizz and I did the "Viper glider build" we had no wiring harness so he modified the Nytro harness to fit the Viper chassis and all it's components. Your's will be a simple engine swap.
Rye_Guy78
- Oct 31, 2014
Thanks!Engine itself is identical. Plug and play. When Grizz and I did the "Viper glider build" we had no wiring harness so he modified the Nytro harness to fit the Viper chassis and all it's components. Your's will be a simple engine swap.
kennyspec
- Sep 30, 2009
- stonewall, manitoba
- nytro
The viper engine has two oil pressure sensors located on a bracket by the oil filter. The Nytro engine only has one and does not have the holes tapped in the block to mount the bracket. You will need to get a T fitting to mount the two sensors in the factory Nytro spot. I am currently going through this right now.
I have also thought of relocating the second oil press sensor to the port on the front of the head.
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
Any input on this? I have a line on a reasonably priced used 2016 Viper with a MPI turbo and blown motor, and another line on a used Nytro engine. Just looking to see if it's a worth while project.
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
If using the Viper electronics and a Nytro motor the oil pressure sensors will need to be addressed. If the Nytro motor, wire harness and electronics are transferred over to the Viper that gets more complicated but doable.
https://ty4stroke.com/threads/viper-glider-build.141852/
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
I saw your thread but only can get my hands on the Nytro engine from a wreck, no electronics.
The oil pressure sensors is what I was more concerned about, if someone had come up with a solution that worked to incorporate that 2nd switch. If the headache is even worth it or should I see if I can find a Viper motor...
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Someone did it awhile back but I can't find the thread. If I remember right he installed a Tee fitting for both sensors but the problem was finding a Tee with compatible threads. The sensors are not pipe thread, they seal with an o-ring. I think he might have had the Tee fitting made or maybe he finally found one. This wouldn't be an issue for me and I wouldn't hesitate to install a Nytro motor in a Viper if the price was right or that's the only motor I could find.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
Ok, will have to weigh that out. So the Viper harness (other than oil pressure switch and sensor) will plug into the other sensors on the Nytro engine?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a mcmaster carr number somewhere for the exact fitting needed to t off the oil pressure
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Yes, it'll all plug in. You'll just need to remove the two oil sensors off the old viper motor and install them with a Tee to the Nytro block.
mbarryracing
- Aug 31, 2007
- Springville NY
1996 Vmax 600XT
OK, I'm armed with data now to make a good decision. I will go look at the engine first to make sure it's worth the trouble now versus going out and buying a used Viper engine. I would be a backup sled anyhow.
Thanks guys
Thanks guys
Gride188
- Mar 10, 2013
Do you Have a part number for this fitting ?I have a mcmaster carr number somewhere for the exact fitting needed to t off the oil pressure
