will the Camoplast extreme track fit on my Apex?
So do I have to cut the track or trim something on the heat exchanger? or does it fit perfect?
I have put a many of 2.5s on Apexes. A 5.5-6" rail extension will make the 174 fit.
There is no need to trim the track for it to fit. The 162" will be a simple swap. If you grind the middle raised fin on the front heat exchanger off, it will clear better, but it should clear without doing this- but not by very much.
