DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
How do you support the back end when you put it on its side?I have a handlebar stand that I use to support the sled while on its side.
Do it all the time, both sides too.
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
Not sure what you mean. I just turn a 5 gallon pail over, pull the sled over, line the end of the handlebar to the center of the Pail and slowly set it down...... It's unnerving the first time, but once you prove to yourself it works, you won't have any issues. Back end doesn't kick out at all.How do you support the back end when you put it on its side?
No need to. The handlebar stand is just an axle stand that I welded a sort of cup on the top.How do you support the back end when you put it on its side?
Usually the track at the back is still touching the floor. If you want to spin the track for whatever reason while in this position, use some six x six wood block under the running board edge near the back, but be careful not to bend the running board as it isn't real strong in that area.
DMCTurbo
- Nov 12, 2005
I'll rephrase my question.
My skid is out of the sled and I want to install it. Sled is currently right side up, rear bumper hooked up to my winch setup. I can't just drop the rear on the floor cause it'll mess up the snowflap. Do you just roll it over and sit it on the running boards?
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
I've heard of guys using old sliders layed perpendicular in the track, and used sort of like a slide/shim to get the skid in. I can lift the rear end way up on mine, and I just kind of nose it in and flip the back over.
You could probably flip the sled on its side and use the winch to hold the tail off the ground if you wanted.
DMCTurbo
- Nov 12, 2005
That's what I'm thinking. I have the skid in the track but for some reason can't get the front hooked into the shaft. It gets harder every year lol. Figured I'd give it a try on its side. Thanks for the help.You could probably flip the sled on its side and use the winch to hold the tail off the ground if you wanted.
Fleecer
- Jun 13, 2014
- 2019 SRX
DMC,That's what I'm thinking. I have the skid in the track but for some reason can't get the front hooked into the shaft. It gets harder every year lol. Figured I'd give it a try on its side. Thanks for the help.
To get the front of the skid up high enough to hook it to the cross shaft, I put a floor Jack under track/front of skid. Usually, I lift it a foot, lower on wood block, place the Jack perfectly, and lift all the way up till skid is in.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
DMC I use a winch to raise and lower the back end for suspension removal and install. When trying to get the ears back onto the shaft it's best to raise the back end high (same height when they drop out when removing). Use the track as your friend now by pushing the front of suspension up with your hand under the track, it will put the ears in line with the shaft. The suspension will move forward real easy being it's pitched and only touching the rear tri hub wheels, just move it forward now and its in. Lower winch and your done.I'll rephrase my question.
Goose1200
- Nov 5, 2016
- 2017 sidewinder ltx le
That’s kinda how I do it too. I use a floor jack on blocks on the ground at the front of the suspension so the jack is above the rails of the sled lift and start jacking up the front until hooked on the shaft and then I lift the rear to slide a second jack under the back and jack the rear until the bolt holes line upDMC,
I do like Fleecer and Goose also, however, the reason I like to use a floor jack under the suspension is so that I can unhook and drop the torsion springs. With the floor jack under the skid, this allows the torsion springs to hang down, not to mention it is much easier to line the rear holes up not fighting the springs. Id it is still difficult, I slide the rear axle ahead all the way.I'll rephrase my question.
DennyTuna
- Jan 28, 2017
- Ohio
97 SX Vmax 600
I use a ratchet strap hooked to the stopper shaft in back over torsion spring to the loop on the front W arm. Lower back of sled, tighten strap to line up holes insert bolt.
DMCTurbo
- Nov 12, 2005
I do that too. Makes it alot easier to get in the track.I use a ratchet strap hooked to the stopper shaft in back over torsion spring to the loop on the front W arm. Lower back of sled, tighten strap to line up holes insert bolt.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
I do exactly the sameI use a ratchet strap hooked to the stopper shaft in back over torsion spring to the loop on the front W arm. Lower back of sled, tighten strap to line up holes insert bolt.
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
His works on all suspensions just like releasing he spring
DMCTurbo
- Nov 12, 2005
Thank you Fleece! I put the jack under the front of the track, raised the rear to 4' or so then started raising the jack and voila she went into place by itself. Literally took 5 minutes!DMC,
