n2oiroc
is the apex windshield bag big enough to stuff a boondocker box (4.3" x 2.7" x 1") in? also, does it use the dash screws to hold it in place? thanks!
Bigger Hammer
The Yamaha bag uses 2 of the windshield screws. As far as being big enough for a Boondocker box, I don't have one (Boondocker) so I wouldn't know.
ReX
I just did a quick measurement of mine. A 4.3"x2.7"x1" box should fit fine with lots of room to spare.
The windshield bag is an oddball shape but in general the width varies from about 4" to 12" at the top, the depth varies from 2"at the edges to 12" in the center and the "height" varies from about 3" to 5" (3" at the zippered opening).
It also looks like it would fit in the new Apex handlebar pad within the storage pouch. It would pretty much fill it up though.
n2oiroc
perfect, thanks!
SRXSex
bag
I find that no matter what, my windshield bag blocks the upper part of the display and there is nothing you can do about it. I always have to lift it up to see the small part of the display that shows the errorcode and such.
The boondocker box will be an ugly fit.
skidud
Re: bag
SRXSex said:I find that no matter what, my windshield bag blocks the upper part of the display and there is nothing you can do about it.
You have it upside down. Turn it over. Zipper starts on left side. It doesn't block anything.
Sidewinder
- Mar 19, 2005
- Ontario Canada
- www.streettechracing.com
- 2017 Yamaha Sidewinder LTX LE
- Waterloo
All I can tell you is, if you put your keys for the truck in there and forget to zip it closed they are still there after a day of riding.
Thank god.
Thank god.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
Re: bag
I had the same problem.
...sooo, I removed mine, turned it over and resecured it. Now it leans towards the windshield and NO MORE blocking my guages!
SRXSex said:I find that no matter what, my windshield bag blocks the upper part of the display and there is nothing you can do about it. I always have to lift it up to see the small part of the display that shows the errorcode and such.
