twomorestrokes
I know this has been discussed but I couldn't find it off a search. What do you guys use to bring back the shine on a windshield?
Pulled a good one and removed my trail permit with Goof Off. What a mistake, it messed it up fast. Bottom line was that I had to use rubbing compound and now the whole lower half of my w/s is hazy and looks like poop. I tried bringing it back with Mcguires and it helped but not a lot. Time for a new one?
big_ry_ry
windshield
I would probally buy a new one, I am looking into a new shield myself
twomorestrokes
I have a spare but it's off a Nytro. Looks a little too cold to me. I'd like to get this one looking better.
Tork
Once you get that solvent penetration in plastics even plexiglass I have never been able to fix it and I have tried nearly everything
APEXLIGHTNING
i use meguires plastix plastic polish. its designed for clear plastic. wont take out deep scratches but it shines up the windshield pretty good.
Mikecam
You could try to paint it from the inside to hide the blemish, other then that I think it is time to buy a new one.
sinjin
What do you guys use to remove the stickers that won't cause this??
GypsyRoots
A blow dryer or heat gun helps a lot!
Yama-Crazy
W-D40 works great to remove the glue...
I usually end up using WD40 to remove the residue left behind after removing the sticker. Takes a bit of time but eventually it does the trick and then just wash away the WD40 with soap and water.
GypsyRoots
I mean before you even start to peel it off...should have said that.GypsyRoots said:A blow dryer or heat gun helps a lot!
twomorestrokes
I'll try the plastic polish. I've got it looking fairly good now but it still needs some work. Lots of swirl marks from rubbing on it. The black w/s bag behind it helps as does the fact that it's smoked, not clear. I've heard the WD40 trick, and I should have done that. Could have sworn I used Goof Off on my wife's windshield last year with no problems. That's what I get for thinking. Thanks for the help guys.
Grimm
Did you try using a polisher/buffing wheel?
twomorestrokes
I wish I had one. I have an orbital but that did not do the trick. I have to buy a buffing wheel soon anyway.Grimm said:Did you try using a polisher/buffing wheel?
