briane
- Jul 24, 2016
- Iron Mountain MI
- 2015 SR VIper LTX SE
I picked up this 1,000 lb motorcycle stand at Harbor Freight. On sale now for $299. I think it's the best equipment investment I've ever made. It's a back saver. Wish I would have bought it 20 years ago...
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Since the skis are not supported, do you have a block underneath the belly just ahead of the heat exchanger taking the load?
MS
MS
briane
- Jul 24, 2016
- Iron Mountain MI
I have cut a piece of 2"x6" lumber that spans across the under the lower control arms to support the front. A block under the belly pan would work alsoSince the skis are not supported, do you have a block underneath the belly just ahead of the heat exchanger taking the load?
MS
briane
- Jul 24, 2016
- Iron Mountain MI
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
I have the same lift and I made a angle Iron frame that the skis sit on. It bolts to the tire clamp bolt holes.
- 12K
