rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
super_rash
- Feb 24, 2014
that looks really good man...
rangermike14
- Feb 19, 2015
- Byron Center, MI
- 2006 Apex
1998 SRX 700
Thanks!
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
Real niceEnded up having mine custom done with a bit of added foam and is stiffer also. He put gripper material on the top also. I'm very happy with it so far!View attachment 111657View attachment 111658 View attachment 111659View attachment 111660
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Ted Jennety Clutching, jetting, air box mod.
Arctic Cat Z1 Turbo 128" Rear Suspension
128" Hacksaw 1" track.
Heated seat
I wonder if you can get the black/blue for the RX1
BigDogrx1
- Dec 2, 2014
- SOO (UP) MI
- 2003 rx1
The WRP SEAT for RX1 is only made in black I called company because I wanted black/red, only black made tho to keep price down?I wonder if you can get the black/blue for the RX1
polarisconvert
- Mar 22, 2006
- Corunna, MI
- 2005 Yamaha RX1
Heated seat
Sent from my SM-G920V using Tapatalk
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
If you really want the second color, ask WRP, if they will include enough extra material with your purchase , so you can take the cover to an upholstery shop and have them replace those colored panels , as it should be an easy process, before they assemble the new cover and foam.Thanks
OR send your seat to BIGDOG RX1 's upholsterer , as that is the nicest custom job , I have seen .
What ever route you choose , get the seat raised , and add a handlebar riser , and you will be very happy !
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
yamaha blue
- Jan 9, 2017
- pickering
- apex and viper
I am looking at buying this seat. I just wanted to see from those of you that have it if it has had up and you still love it. please let me know. thanks!
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
Yup, love it. The whole sled now really, very easy to go too fast over garbage with the hygear setup and more ski shims. Only thing I would say is my legs are a ltitle achy since it's so easy to pull up off the seat, I did it a lot. Trails around Barnes to Montague were like the old days, in the afternoon, with lots of bumps. Still can sit if you want and chase those pesky standuppers too!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have the WRP seat and the Star kit .Yup, love it. The whole sled now really, very easy to go too fast over garbage with the hygear setup and more ski shims. Only thing I would say is my legs are a ltitle achy since it's so easy to pull up off the seat, I did it a lot. Trails around Barnes to Montague were like the old days, in the afternoon, with lots of bumps. Still can sit if you want and chase those pesky standuppers too!
Same comments as above .
I have the sidewinder and my Apex XTX , and rode them both yesterday .
When I got on the Apex with the WRP seat it felt higher than the sidewinder , and then similar after a little sag.
Both sleds can chase my kids snopro race sled sitting down , as he is standing.
DJ Hennessy
- Jan 30, 2016
- Barrie, ON
- 2016 Yamaha Viper RTX SE
2006 Yamaha Apex RTX
Can anyone that has done this mod, I'm assuming has done a handle bar riser as well, help me out with a throttle adjustment question? Every time I turn the nut at the motor mount is seems to either take from one side, not actually add to the length??? I added now a powermadd extension and it does the exact same thing, so not really sure I needed it since it didn't help matters... Also, when I turn the steering wheel it engages the throttle... FML! Please help!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have the UP North riser 2.5 ", and no throttle adjustment needed.Can anyone that has done this mod, I'm assuming has done a handle bar riser as well, help me out with a throttle adjustment question? Every time I turn the nut at the motor mount is seems to either take from one side, not actually add to the length??? I added now a powermadd extension and it does the exact same thing, so not really sure I needed it since it didn't help matters... Also, when I turn the steering wheel it engages the throttle... FML! Please help!
You may re route the cable around to the front of the bars , if I recall what I did , or if still need more free play , look further down the cable for any other rerouting or undo some tie downs .
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
I only have the 6 inch riser but it fits me well. No need for longer cables with the 6.Can anyone that has done this mod, I'm assuming has done a handle bar riser as well, help me out with a throttle adjustment question? Every time I turn the nut at the motor mount is seems to either take from one side, not actually add to the length??? I added now a powermadd extension and it does the exact same thing, so not really sure I needed it since it didn't help matters... Also, when I turn the steering wheel it engages the throttle... FML! Please help!
- 9K
