WRP Tuff boards, need opinions.
I put on the GYT tunnel reinforcements and cut out the leftover on the footrest,great stiffnes on the tunnel and boards.
I have heard that the better boards does not last, and wondered if the wrp boards are any better? I really want the airframes, but want to check out other alternatives since they are half the price as the airframes.
I have the wrp boards with 1500 miles and no problems yet. I think they work pretty well but I believe the airframes would be a step up.
Ok, thanks. I want the airframes, but don't wanna use more money than I have to on this..
You don't happen to have any pictures of them installed on your sled?
Okey,
As of this moment i think I'll go with the wrp boards, but theres always a chance that I change my mind before i actually order them.
Some pics would be great ;)!
Anyone got pics of the 2010 wrp boards on the 2008 Nytro?
I placed an order for the new style boards, but they seem to be shorther than the 08 ones..
I have the WRP's on mine, have run them for 2 seasons and am going to the airframes. The WRP boards are ok but still bend.
Here is mine, powder coat obviously, but gives you and idea. I had a write up on the install on here, I will see if I can find it.
http://www.ty4stroke.com/viewtopic.php? ... rp&start=0
There ya go. I broke my first set, not sure if they were just a bad set of metal or a design flaw. WRP warranted them no questions asked. The new set I had bars welded in place where the old boards failed, I am 6'6 240 so maybe me standing on them was the reason, no issues since the reinforcement.
Thanks man.. I was out looking at it now, and it seems like the rear suspension mounting bolt will be in the way.. Guess I'll have to mount the drop brackets at the same time. Parts will arrive early next week so we'll see then..
Anyone know someone who has mounted the 2010 boards on a 08 Nytro before?
I'm looking forward to this mod ;)!
What is your rider weight.
I had the WRP boards 2 years ago - at the end of that riding year they were bent beyond repair.
Went to the Air Frame boards last year - night and day difference in strength and snow build up or should I say lack there of now.
Yes they are more money - but my original question still stands. What is your rider weight.
Mtdream and I have some posts from last year if they are still around going back n forth on how to fix WRP boards - pound a 1/4" cold rolled steel rod down the outside bar is the fix. Mine were too far gone. There should be some pictures of mine last year on a post too if you can find it. Gravity has a strange affect on me where i stand :) I am 6'3" and 280+ with gear. WRP boards did not hold up for me - situations are different per person as well as rider style. IMO - spend the extra now and you will save in the long run.
